Originally Posted By: PontiacFan
new observation.
After aoout 675 miles with 16 oz Kreen in the crankcase, I noticed about 15 seconds of sharp lifter clicking on my start to go home from work. Car had been setting for about 8 hours and outside temp about 93. Go figure? Cleaning engines often make funny sounds.
Now about 900 miles on my kreen additive. Car is running fine. very little, if any, engine noise. Mileage seem up etc. However, weather has been cooler and have not used air as much. Blotter test oil sample is getting darker each check. Have not seen a drop in oil level since adding. not sure there is much kreen evaporation. i will watch closely.
Since your oil is dark via the BLOTTER TEST, will you be running another Kreen Application.
I was thinking about running my current Kreen fill about 1,500 miles then doing a oil/filter change. Possibly running 16 oz Kreen through my fuel. Perhaps later running 16 oz Kreen in my oil again before winter. I have one more quart of kreen.
