I am looking for a grease that would work better than a standard lithium based #2 for my no till drill. The drill has coulter arms that pivot on pins and are pre loaded with heavy spring pressure. WHen in operation, the pins occilate back and forth about 10 - 15 degrees. The lithium grease I am using seems to not "stay put", and I am constantly having to grease those pins.
Was wondering if a 5% Moly would be better? If so, is a lithium complex or a calcium sulfonate base better? If the calcium is better, will it be compatible with the lithium that I have been using?
I was thinking about Amsoil Synthetic Polymetric Off road #2 would be a good grease, but would like to find something comparable that I can find locally. (Triton XD5, Omnigaurd XD5 etc) Any thoughts or suggestions?
Thanks.
Thanks.
