We had lots of issues with SLX and with Castrols in general in Poland (mainly cheap GIII) but maybe it was our local blend - for many years even blended in Poland, now we can buy it from Germany but also very cheap and poor quality - hard to believe it is original ;-(
In my opinion when you run longlife using low saps / low TBN oil then TAN is more representative than TBN and in fact even not only low saps / low TBN but in general longlife - example:
after 10k miles (gasoline engine) on AMSOIL SSO 0W-30 TBN is 4,6 (one of UOA I know - virgin oil has TBN=13,2) so it is really a very strong oil but using dirty sulfur fuel or LPG we can have much higher TAN very soon - I'm sending another sample of this used oil to Blackstone to check TAN additionally.
How is your DPF doing on the Delvac? We tested AMSOIL DEO CJ-4 on Subaru Boxer diesel with no DPF issues or even increased soot level at DPF - so I think that not only saps % is a key but quality of oil (base) as well. Nevertheless there was significant difference in soot level on Subaru Boxer diesel DPF (~500km test) between 5W-30 low saps and 5W-40 API SL "conventional" saps oils (both Shell - 5W-30 was GIII/GIV synthetic and 5W-40 typical GIII).
