A friend of mine was going to throw out a chainsaw that belonged to his father, who died in I believe 1987 or 88. I can't imagine its been run since then. He said I could have it so I snagged it and didn't do anything with it for a while.
It's a Dayton 2Z461 (Poulan 361 clone) which were last made in 1975. I fiddled with it a bit a few days later. It has gobs of compression and was tough to pull. Though I know I shouldn't have, I left the 1/5 of a tank of 20+ year old mix in and filled it with fresh mix. Then I filled the chain oil up with a few partial bottles of Stihl bar and chain oil my dad had lying around. Then I sprayed the carb out with carb cleaner to find that it would in fact start on carb cleaner. I couldn't get it to stay running, so I left it. Today I decided to try again. I noticed there was no fuel in the fuel line to the carb. So I took it off and sprayed down the carb and down the fuel line. After that and some priming with more carb cleaner, it started right up. I was absolutely amazed. Again, this had been sitting in a dank garage with no storage preparation and a good bit of decades old gas!
I'm extremely happy, now I have a nice old chainsaw. Only downside is it has the original 17" bar and chain which as far as I can tell they don't make chains for anymore. Apparently these take an aftermarket 24" bar happily, so that'll probably be my course of action when I need a new chain.
