My neighbor just gave me(just gave it to me!) a Honda Harmony 215 lawn mower with a GXV 140 engine(135cm), double blade(one atop the other) and plastic deck.
Don't know what year it is and either does he(bought it used). He is moving and he bought a brand new rider.
The mower was sitting all winter long w/o any fuel in the tank. I poured in just a bit, threw down the choke lever and with one pull(a whimpy pull at that) the thing started beautifuly! Cut my lawn with it but I had to push the thing...Not bad!
This mower is very nice after I cleand it up, all cables are in perfect condition and the springs for the rear flap(cover/shoot/bagger area) are "stainless" and clean.
The only thing that doesn't work is the rear self propel.
Pull the lever and nothing! The cable is fine and unbroken/perfectly attached.
The lever(outside the gear box), in which the cable is attached to(under the deck), doesn't seem to move freely. I tried to get it moving, spraying a little penatrating fluid.
I Lifted the mower and set it on 2 saw horses so I could climb under the mower like a car. Looking up, I can see everythink reasonably well.
ANYWAY!
Sorry for the long stroy. But, does anyone have any suggestions for what to do in order to get the gear box working?
Can I just open up this gear box from underneath? Will anything fall out if I do?
My neighbor mentioned that it needed a new cable for the self propel but, after inspection, the cable looks great and it's the lever that doesn't enguage the drive...IDK!
Thanks for any help,
CharBaby
ANYWAY!
CharBaby
