I have a 2004 Chevy Impala 3.4L with approx 110k miles. This will be the first time I will be changing the trans fluid by dropping the pan and changing the filter. First time it will be done on the vehicle as well. I'm looking for some suggestions on what kind of fluid I should top it off with. I was looking a the Valvoline MaxLife DEX, but I'd like to get some input from the veterans on here.
Manual calls for Dextron III.
P.S. - I believe the factory pan gasket is reusable on this car, so I just need a filter in addition to the ATF. Does it matter if I go to the dealership or to AAP for the filter (AAP only sells the filter with a kit)?
