There's no special requirements because it's a pressure washer, so any of the other OPE-based threads on oil choice in here are valid.
Actually, being a pressure washer is a pretty good gig for an OPE engine. Assuming that it's designed well, the pump is sized to load the engine up to a specific percentage of it's maximum (which is far from 100%). Operation is usually constant RPM, it never gets bogged or overloaded, doesn't get run through clouds of dust kicked up by blades, never hits a tree root or debris.
There are some that feel that pressure washers work particularly hard compared to other OPE. I disagree. I believe snowblowers have the worst jobs. People will bog those suckers with EOD until they stall at WOT sometimes.
