Another question while I'm at it :
Do I need to have a new gasket for the final drive cover? Someone online said I could use some gasket stuff from a parts store instead.
I could not get the final drive oil changed yet - couldn't get the tranny cover off for some reason. Oil looked fairly clean in the fill hole. I may get a vacuum pump and be able to pump it out of there.
Manual says it only needs to be changed every 10,000 miles of so but someone online said to change it once a year, which may be OK if I can pump it out of there.
