Quote:
sayjac, ive read on here that the z1 fluid gums up, I have a habit of using whats suggested by the manual. Do you think if cars under warranty, one should stick with suggested fluids??
When it comes to Honda AT's, I'd stick with Honda's recommended fluid under warranty. Should something happen, eliminate an excuse/reason for Honda not to honor the warranty. After that, up to you, Amsoil does seem to have good rep here with use in Honda AT's.
As for Z-1, can only go with my experience which has been good. Basically it's not broken (knock wood), so no need to fix it. JMO
