The first 20K UOA is here:
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1953299#Post1953299
Miles on car 231,143, miles on oil 41,023 miles
Total oil used is 7 Liters of LiquiMoly Longtime Hightech 5W30 and 2 quarts of Redline 30WT race oil and 8oz of Z-MAX. One VW full flow filter and an Amsoil BE-90 were used.
First column is UOA at 20K, second column is UOA at 41K. All UOAs were done by Polaris lab.
Iron...............23..........45
Chromium........1..........1
Nickle..... .......0..........1
Aluminum.........5..........4
Copper............3..........5
Lead...............3..........7
Silicon.............9..........8
Sodium............6..........3
Molybdenum......311........273
Antimony..........2..........0
Manganese.......0..........1
Boron..............27........20
Magnesium.......172.......142
Calcium...........2770......2701
Phosphorus.......1577......1353
Zinc............ ..1424......1382
Fuel............. 0.7%...........0.5%
Soot............. 0.1%...........0.2%
Water (IR)...... < 0.1..........< 0.1%
VIS @ 100C ..... 11.9 cSt......11.7
TBN.............. 7.39...........2.48
IR Oxidation.... 51.............53
IR Nitration..... 17.............21
The Oxidation number is due to the Red Line oil.
I refilled the car with Red Line 5W20 and replaced the full flow filter but did not replace the BE-90 since it still has very good output. I replaced the air filter but not the fuel filter.
