Originally Posted By: beanoil
Originally Posted By: metroplex
I don't see the JASO MA on any of the 15W-50 oils. Lots of people seem to use those in motorcycle engines, but unless I see the JASO MA on the back of the label I won't use it.
Ducati's air-cooled V-Twins are spec'd to run a synthetic 10W-40, I don't see any reason to run 15W-50.
JASO MA is a friction modifier specification. With HD having a dry clutch, (along with Guzzi, BMW, a few others), it's a moot point. Run the proper weight recommended by HD, and keep on riding.
FWIW, I have run a lot (gallons) of M1 15w50 in wet clutch bikes with nary an issue. It is a very good oil, but does shear to a 40 weight pretty quick.
The Harley davidson clutches are bathed in oil,I thought that made them a wet clutch?I have a sportster and the clutch is in with the trans/primary fluid.On other Harleys the clutch is in with the primary fluid.
Can someone clear up the gl-5 in the trans?I thought gl-5 oil is too corrosive for trans(yellow metals).If it has a mt-1 rating does that mean it has no corrosive properties????
