What would you use to clean a PCV valve, MAF sensor cleaner or throttle body cleaner?
The PCV valve has 25k on it. I haven't taken it out yet, but plan to later today to see if it is clogged or not. I had a intake manifold gasket issue, so I'm wondering about the valve. If it seems OK, I figure I might as well clean it while it is out. If it seems plugged a bit then I'll replace it.
