245,136 miles
22,536 miles on oil
NO MAKEUP OIL
NO OIL LOST (LEVEL FULL in = LEVEL FULL out)
NO FILTER CHANGE (during this 22k run)
At least 25% was towing a a trailer between 5000 and 8500 pounds. Two trips between Columbus, GA and Pennsylvania were over 7000 each.
(All in PPM, unless otherwise noted)
CU - 16
FE - 39
CR - 1
AL - 7
PB - 6
MO - 303
P - 931
ZN - 1093
MG - 732
CA - 1128
NA - 8
K - 1
ANTIFREEZE - N%
FUEL - N%
H20 - 0.0%
SI - 5
VISC - 15.87 CST
SAE - 40
SULFUR - 9%
OXIDATION - 3%
NITRATION - 12%
SOOT - 0.9%
Schaeffers noted the oil to be normal and to extend the change to 25,500 miles.
Thoughts?
22,536 miles on oil
NO MAKEUP OIL
CU - 16
FE - 39
CR - 1
AL - 7
PB - 6
MO - 303
P - 931
ZN - 1093
MG - 732
CA - 1128
NA - 8
K - 1
ANTIFREEZE - N%
FUEL - N%
H20 - 0.0%
SI - 5
VISC - 15.87 CST
SAE - 40
SULFUR - 9%
OXIDATION - 3%
NITRATION - 12%
SOOT - 0.9%
Thoughts?
