A friend of mine just picked up a '98 V70 (130K) with what I'm guessing is the original transmission fluid. It shifts just fine but I've convinced him to swap out the fluid. And since I used to have a V70, I'm getting roped into helping him...
I'm going to do a cooler line flush, which is super-easy on this car (and the recommended procedure), but I don't know a thing about Dex III fluids. I swapped mine to M1 ATF, but this guy is incredibly cheap. Anyone have any recommendations for a good, cheap, readily available ATF? Are all of the "Dex" fluids backwards compatible, i.e. will dex VI work in this car?
Thanks!
Thanks!
