n the case of TMI the Fuel melted but did not breach the Reactor Vessel. Even if it would have, the fuel would have melted through the vessel and the Reactor building had already 9 feet of water.
The concrete in the area of the vessel was around 8 feet of concrete as I recall. It was poured on bedrock. The amount of heat absorption there was immense. And the Reactor building had reinforced walls of 3' thick concrete and could maintain an internal pressure of 56 psi. It had a steel liner 3/8" thick and could take a direct het by an airliner.
I don't know if the Japanese reactors have this kind of system and what the actual Reactor Building consists of.
As we speak the core is still producing 100 million Btu's/hour.
