Hi all!
I'm new to the forum and it was suggested by the Cummins forum that i source some help form you guys. I just did my first oil analysis a while back on my 06 dodge Cummins. I was curious at the time how John Deere 0-w40 CJ-4 Syn would pan out in the Cummins. The 06-07 are very well known for sooting up oil in a hurry. So the CJ-4 Syn JD oil looked like a good match. The analysis came back good other then showing higher then normal fuel in oil levels 4% ??? I know that the 5.9 Cummins is prone to cylinder wash in cold low heat conditions when your extending idle time. And here in Manitoba ...its [censored] cold and my truck probably only spends 40% of its life right up to temperature. Has anyone else ran into this same problem in cold conditons... or is there likely a problem here?? The oil has about 197hrs 11500km. 2500km towing and the rest all light highway miles. All the run time was in the last 2 months in cold conditions (-10 -38) with no power adders installed on the truck. Any help would be greatly appreciated. Thanks!
