I'm going to change the radiator on my friends Saturn SL1 later on this week and want to do a thermostat change and coolant flush at the same time. My question is, Should I run the flush through the old radiator before I install the new one? Or should I go ahead and replace the thermostat/radiator and run the flush through after that? I'm leaning torward the latter because I see no reason to run the flush through the old radiator. What do you all think?
