My Ranger is going in for some collision repair/body work on mon. Figured a "welcome home party" is in order after a week of being without my truck.
20k km on it, been wanting to do an early change of the diffs, transfer case and manual trans to flush out any break in grit and change to top of the line synthetic fluids.
Climate here ranges from -20 deg C to 30 deg C winter to summer, most of the Ranger's duty is daily driver, but there is a good bit of hauling and towing in the mix, and I do tend to drive pretty hard, I love to hear an engine rev.
Diffs call for 75w90 gear oil, Trans calls for Mercon ATF even though it is a standard, like most standard Fords do.
T case calls for Ford transfer case fluid. I have read older Rangers used ATF with the same Tcase, and the new fluid is basically ATF that is "slipperier" as there is no need to let clutches or syncros bite in a Tcase.
Recommend me some fluids, guys!
Also, I have never opened up a diff, my only experience is working on FWD cars with the diff inside the transaxle. Never a RWD/4WD setup.
I know the diff covers have to come off to drain the gear oil, do they use a gasket or RTV or such "form in place" gasket?
Buying a Haynes service manual for the truck before I do this, but real world experience on the diff change is appreciated.
I'm thinking the Ford fluid just might be best for the Tcase, but if I'm wrong tell me why.
And what ATF/MTF has worked best in all your M5OD transmissions?
Favourite gear oils?
This Ranger deserves the best
