Originally Posted By: Kestas
Originally Posted By: Johnny248
However, they do make needles that attach to the end of your grease gun, which you can stick into the boot to lube them. If you look through different service manuals, they will tell you to grease them with those needles.
I must be missing something. How will introducing grease into the boot help the surfaces that needs to be lubed? Lubing through zerks inroduces grease directly to the wear surface. Lubing through the boot just shrouds the area with grease without introducing it to the wear surfaces. Are you sure those needles aren't designed only for use with lube points that have spring-loaded ball openings, like some u-joints have?
That grease gets worked around everything time the joint rotates or moves. Take a boot of a tie rod, and look how much grease is slopped onto the top of the ball joint where the boot covers. I have quieted several squeaking ball joints, idlers, tie rod ends, etc by injecting grease into the the boots. For instance, straight from a factory service manual.
1. Remove the dust cover.
2. Apply the multipurpose grease SAE J310, NLGI No.2 or equivalent to the lip and the inside of a new dust cover. Grease amount for the inside the dust cover (reference): 13 ±0.5 g (0.459 ±0.018 oz)
