This is for a New Holland TS135A tractor. We use it on our farm to feed cows everyday. The OEM recommends 600 hour OCI but I was getting such good results with that decided to go a little longer to 759 hours. Probably do a nice even 800 hours next time. It has a CNH 6.7L engine ( not a Cummins ) with a high pressure common rail fuel system. Using an LF16015 Fleetguard Stratapore filter and Service Pro 15w-40 engine oil with 300mL Lubro-Moly anti-friction. Tractor has 7372 hours.
Iron 54
Chr 3
Al 2
Lead 13
Sili 5
Moly 141
Bor 22
Mag 935
Cal 1541
Phos 961
Zinc 1246
Fuel Soot .4%
H2O Vis 14.2
TBN 6.4
Oxid 14
Nit 18
Lead was a little high but I'm not too worried about it. Will probably take another sample at next oil change and see if it levels out better.
Iron 54
Chr 3
Al 2
Lead 13
Sili 5
Moly 141
Bor 22
Mag 935
Cal 1541
Phos 961
Zinc 1246
Fuel Soot .4%
H2O Vis 14.2
TBN 6.4
Oxid 14
Nit 18
