My thoughts are there are 2 issues which Honda has combined togehter.
1) break in
2) oil life
The MM may go to 10k to 12.5k on a new car.
After say 6000 miles, you're already probably around 200hrs operating time on the car, and a couple million revolustions, I think the breakin period by this point is satisfied and the system isn't going to break in any more.
However, for issue 2, the oil is still good but this is independent from issue 1.
If you're going to put in the same conv. oil, no point in changing, the oil is still good, you gain nothing.
However if you're going to switch to something more exotic such as Mobil1 0w-20 Advanced Fuel Economy, you will get the benefits of that new oil sooner, which may offset the cost of the wasted still good oil.
I changed on my honda fit at 6000miles at 1year birthday. Used M1 AFE; MM was at 60%, I did notice the engine being smoother after the change; your butt dyno may vary, but I think benefits were had.
There's probably still a good halfquart-1quart of residue oil in the system as it's not a 2drain "flush", so it's still somewhat a gradual changeover...
