It's AMSOILŪ, not Amsoil
by Rat407
13 minutes 14 seconds ago
VW Passat 2007
by madRiver
34 minutes 32 seconds ago
Review: CVJ Remanufactured CV Axles
by The Critic
Today at 03:40 AM
Towing without 85w140?
by OilFilters
Today at 03:07 AM
2015 VW GTI autobahn oil questions
by Skyalbo
Yesterday at 11:28 PM
Corrosion in the garage - salt or humidity?
by Kurtatron
Yesterday at 11:13 PM
Darn dogs
by AZjeff
Yesterday at 10:21 PM
New GC?
by Bullwinkle007
Yesterday at 10:04 PM
The guy with the plexiglass head on you tube
by andyd
Yesterday at 09:21 PM
'07 Pacifica Timing Belt Replacement success
by 92saturnsl2
Yesterday at 09:10 PM
SAE 90 v 85/140
by Knuckle078
Mobil 1 5W30-HM 5,011 mi, 1999 Ford Escort
by WA1DH
Yesterday at 08:45 PM
Schaeffer's oil reviews on Amazon
by zfasts03
Yesterday at 07:41 PM
Decent MP3 player
by Ed_T
Yesterday at 07:08 PM
Letgo
by Donald
Yesterday at 06:52 PM
Tire buying advice
by supton
Yesterday at 06:23 PM
Two versions of M1 5w30 ESP now?
by Patman
Yesterday at 06:21 PM
No older cars in New York State?
by Oldtom
Yesterday at 06:19 PM
2009 Taurus strut mount noise
by terry274
Yesterday at 04:38 PM
A3/B3 vs A3/B4, big difference or irrelevant?
by FordCapriDriver
Yesterday at 03:36 PM
dhy808, ROD_Z, lozpxs, danthemanx07, FunktasticLucky
65319 Registered Users
64 registered (2009Edge, 2015_PSD, aquariuscsm, 97K15004WD, Astro14, 4WD, 7 invisible), 1083 Guests and 33 Spiders online.
65319 Members
67 Forums
285956 Topics
#2165603 - 02/08/11 09:16 PM 2007 F-350 6.0L with CO-OP DMO SL 0W-40 17,800 kms
bsigg Offline
Loc: Swan River, MB
I don't know much about this, but looks pretty decent.
I notice that Zinc and Phos are really high.
It did shear down to a 30 weight (which is normal for this engine.)
I did switch this oil out with 0W-30 ESSO XD-3, which makes this engine run better and won't shear down as bad.
The following results were obtained using John Deere Oilscan (Edmonton Lab).
Hours on Oil: 269 hrs.
Mileage on Oil: 17,843 kms (11,089 miles)
Metals (ppm)
Iron (Fe) 32
Chromium (Cr) 1
Lead (Pb) 5
Copper (Cu) 5
Tin (Sn) <1
Aluminium (Al) 6
Nickel (Ni) <1
Silver (Ag) <1
Titanium (Ti) <1
Vanadium (V) <1
Contaminants (ppm)
Silicon (Si) 16
Sodium (Na) 3
Potassium (K) 12
Water (%) <0.05
Coolant No
Fuel (%) 2
Soot (%) 0.1
Additives (ppm)
Magnesium (Mg) 280
Calcium (Ca) 2680
Barium (Ba) <1
Phosphorus (P) 1624
Zinc (Zn) 1942
Molybdenum (Mo) 2
Boron (B) 246
Physical Tests
Viscosity (cSt 100C) 12.2
Physical / Chemical
Base Number (mgKOH/g) 9.2
#2165639 - 02/08/11 09:59 PM Re: 2007 F-350 6.0L with CO-OP DMO SL 0W-40 17,800 kms [Re: bsigg]
m37charlie Offline
Loc: Alaska
I think your "shearing" is primarily fuel dilution.
If it wasn't for that, the rate of TBN retention would allow a very long run, maybe 60-80000km.
I hold this oil in high esteem.
Charlie
05 Unimog U500/Unicat camper/Delvac 1 SHC ACEA E4/E5
09 BMW X5 35d/Delvac1 LE 5W30
88 Toyota OJ50LV OM314 motor D1 SHC
52 Dodge M37/Hercules diesel
#2165792 - 02/09/11 05:02 AM Re: 2007 F-350 6.0L with CO-OP DMO SL 0W-40 17,800 kms [Re: bsigg]
dnewton3 Offline
Loc: Indianapolis, IN
Yes, I agree, looks very good.
I suspect the shearing is a combination of fuel and the HEUI; how much each one contributed would be hard to distinguish. I also susepct you won't see as much shearing with the 30 grade you put in. The HEUI PSD simply seems to prefer the ligher grades, and if you don't feed it one, it will make one for you.
Further, I don't think people should get too excited about shearing; typically it does not manifest itself in wear in a PSD, so what's the real concern? The ONLY reason to fear shearing is if it results in some type of degraded wear protection performance. Generally, that's not happening in the PSD UOAs we've seen here. (I would panic if I saw a 40 grade drop to a 15 grade, but from a 40 to a 30 still stays within the acceptable range for the engine, and the wear metals tell us all is fine).
That load you used performed very well; great oil. I suspect you'll see similar wear protection from the current load as well.
Edited by dnewton3 (02/09/11 05:02 AM)
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
