I asked Pennziol and GM Dexos info using their contact. Here's what I got. I think the best guess would be the PP oil that will carry the logo will be no different than before.
Response from Penn.
Q - Is there any difference between the Platinum 5w-30 currently
found on shelves vs the Platinum that will soon be found with the Dexos1 logo?
A- We have been blending the Pennzoil Platinum Motor Oil SAE 5W-30 since March of 2010. As a result any purchase of the Pennzoil Platinum 5W-30 since then has met the GM Dexos 1. If you go to our Pennzoil or the GM website you can find the information regarding its applicability for Dexos 1.
Response from GM Dexos Info Center:
Q1 - 1. When will we start seeing the logo on retail containers in stores? None of the approved containers show it as of yet.
A1 - You should start seeing the dexos™ logo on containers in retail outlets very soon. Some suppliers have tried to coordinate with GF-5 so there is only one label change rather than multiple changes. Also, there will be a slight lag as inventory is being depleted and the pipeline is being filled.
Q2- For the list approved oils such as Penn Plat, Mobil1 is there a formulation difference between current product on the shelf w/o logo verses the product that will hopefully soon carry the approval logo? In other words, did they have to change anything or did there product already meat Dexos1?
A2 - Mobil 1 and Pennzoil Platinum should meet the dexos specification. Since formulations are considered proprietary by the oil companies, we are not able to discuss specifics, changes or other details. It’s worth pointing out though that dexos licensed products are monitored for field quality by a third party, the formulations are registered / certified and they are traceable back to the raw materials. Those not registered do not meet all these criteria.
