DTD EBay sale
by T4RF. 10/17/18 02:28 PM
My CarHop Experience...
by dogememe. 10/17/18 01:47 PM
Total 10w50 / What is your opinion
by DibroTeam. 10/17/18 01:06 PM
Early Christmas present to me! Air Compressor
by dnewton3. 10/17/18 10:37 AM
Rock Auto 5% off code.
by Sayjac. 10/17/18 09:53 AM
Canada - Marijuana now legal
by Smokescreen. 10/17/18 09:51 AM
Proper sampling
by BigShug681. 10/17/18 09:36 AM
Snow Driving - Engineering Explained
by StevieC. 10/17/18 09:36 AM
Friendly Inspection
by Zee09. 10/17/18 09:33 AM
Shell V-Power NITRO VS "Cheaper" fuel
by Datarock. 10/17/18 09:02 AM
Cut open used Fram Ultra & Subaru OEM
by MrWideTires. 10/17/18 08:31 AM
Cruze diesel oil filter, which one?
by Rat407. 10/17/18 07:17 AM
Kagayaki rice breed???
by RyanHeo. 10/17/18 06:24 AM
Small engine oils
by NHRATA. 10/17/18 12:46 AM
"OEM" Brand Hyundai Coolant/Anti-Freeze
by Gannet167. 10/16/18 11:45 PM
Pentosin Pentofrost A2 vs Peak OET Asian
by tony1679. 10/16/18 11:40 PM
The Youtube Blackout
by Warstud. 10/16/18 09:28 PM
FBM4130, tawas23, wfillier1979, jimmy154, DizzyFrog
66236 Registered Users
99 registered members (53' Stude, Anduril, 97f150, anndel, 2016Accord, 8 invisible), 2,256 guests, and 46 spiders.
Topics292,089
Posts4,873,935
Members66,236
Most Online2,494
Oct 17th, 2018
2007 Cummins 6.7 Fedex Package Van #2153099
01/27/11 11:03 PM
01/27/11 11:03 PM
Carol Stream, IL
filterdist Offline OP
Carol Stream, IL
Let me know what you guys think..
This is a FedEx package van. Heavily loaded from the time it leaves till the time it returns. Idles a lot - no exact hours. Truck leaves at 7:30 AM and returns 11.5 hours later. Obviously it does not idle all day, but this truck probably idles 7 hours/day. Probably shuts down, and starts 100 plus times per day.
Once I get the amounts used for top off I will update the post.
Need any other info let me know! Thanks in advance.
Google Doc. 2007 Cummins 6.7L FedEx Package Van UOA
Re: 2007 Cummins 6.7 Fedex Package Van [Re: filterdist] #2153129
01/27/11 11:40 PM
01/27/11 11:40 PM
Merritt Island FL, USA
chubbs1 Offline
chubbs1  Offline
That is quite amazing. I am not sure I understand do you take care of your own truck or does FedEx use Amsoil? If so, it is a testimonial waiting to happen. That is one of the best UOA's on here considering the pounding the oil would take in an app. like yours.
Can someone dig up a UOA on here that is that good (at any mileage) in an engine that takes so much "abuse"? Let me know? It is almost so hard to believe, I would consider paying for a second opinion.
'12 Charger SXT
QSUD 5w30 OEM filter
'12 Charger SXT
Edge FST EP 5w30 OEM (Mine;)
'11 Hyundai Sonata GLS
QSUD 5w20 OEM Filter
Re: 2007 Cummins 6.7 Fedex Package Van [Re: chubbs1] #2153263
01/28/11 06:06 AM
01/28/11 06:06 AM
Carol Stream, IL
Carol Stream, IL
The whole FedEx Ground and Home Delivery Division Are Independent Contractors. They are responsible for maintaining their own trucks. I have a few FedEx accounts at the local terminal, with only one of them choosing to do oil analysis.
Maybe next go around we will try another analysis company.(Blackstone?) This will be solely up to the customer as it is an Amsoil Commercial account and gets discounts on oil analysis kits and results usually within a day or two.
In addition my customer is going to change the filter (Donaldson Standard)and top off within the next week or two. The filter now is whatever the local mechanic uses. Likely a Fleetguard.
Re: 2007 Cummins 6.7 Fedex Package Van [Re: filterdist] #2154385
01/29/11 10:24 AM
01/29/11 10:24 AM
Retired | Wausau, WI
Johnny Offline
Johnny  Offline
Here, lets see if this works so everyone can see it better.
Re: 2007 Cummins 6.7 Fedex Package Van [Re: Johnny] #2154489
01/29/11 12:26 PM
01/29/11 12:26 PM
Carol Stream, IL
Carol Stream, IL
Thanks! Much better.
Re: 2007 Cummins 6.7 Fedex Package Van [Re: filterdist] #2154542
01/29/11 01:36 PM
01/29/11 01:36 PM
Indianapolis, IN
dnewton3 Offline
dnewton3  Offline
Indianapolis, IN
Wear metals look decent but Fe could be better. 43ppm in only 11k miles is not great, but not horrid.
TBN is a concern. At 4.4k miles it dropped to 7.8. Now, a bit more than 6.6k miles later, it's down to 4.4. If the TBN degredation is fairly linear, then I wonder how long this load can last? 15K? a bit more?
Being a 6.7L, I presume it has a regen cycle with DPF? If so, it must not see many cycles, because the fuel is low.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: 2007 Cummins 6.7 Fedex Package Van [Re: dnewton3] #2154572
01/29/11 02:13 PM
01/29/11 02:13 PM
Carol Stream, IL
Carol Stream, IL
I would imagine since this truck is fully loaded to and from the FedEx terminal (partial highway) and driven fairly hard it would not likely have to go through many regen cycles? Even though it does a lot of idling throughout the day.
After filter change and top off how soon would you recommend doing another oil analysis based on the past trends?
We will contact OAI but other input is great as well.
Re: 2007 Cummins 6.7 Fedex Package Van [Re: filterdist] #2154897
01/29/11 09:38 PM
01/29/11 09:38 PM
Indianapolis, IN
dnewton3 Offline
dnewton3  Offline
Indianapolis, IN
I would agree that the heat generated from all the normal daily op's are keeping the regens to a minimum; hence the low fuel%.
Top off's will keep the TBN (and the rest of the add pack) bolstered. Of course, top off's are only needed as the consumption provides. How often do you top off?
If you're looking to determine an OCI interval, I'd UOA about every 5k miles. That will allow you to develope the ranges and trends. It's expensive at first, but if you establish safe extended OCIs, it will pay for itself in the long run. Amsoil is typically a good bet for extended OCIs; great products, overall.
Re: 2007 Cummins 6.7 Fedex Package Van [Re: dnewton3] #2155349
01/30/11 11:05 AM
01/30/11 11:05 AM
Carol Stream, IL
Carol Stream, IL
Just spoke with the customer. No top off oil used.
Thanks for your input. 5K UOA is the trend we planned on following.
Re: 2007 Cummins 6.7 Fedex Package Van [Re: filterdist] #2155365
01/30/11 11:35 AM
01/30/11 11:35 AM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
Wow-if you can maintain those LOW soot numbers, with no bypass system-you're on to something here! Help us out & let us know which filter you're running on this motor (Fleetguard Stratapore possibly?). Also see if they can get a TAN/total ACID number on your next UOA to see if the high idling, in cold weather, could be creating acid that could be contributing to the high Fe #.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: 2007 Cummins 6.7 Fedex Package Van [Re: bullwinkle] #2155437
01/30/11 01:01 PM
01/30/11 01:01 PM
Carol Stream, IL
Carol Stream, IL
I would have to yes, Fleetguard. The shop that works on his equipment is all Fleetguard.
Re: 2007 Cummins 6.7 Fedex Package Van [Re: filterdist] #2155618
01/30/11 04:57 PM
01/30/11 04:57 PM
Indianapolis, IN
dnewton3 Offline
dnewton3  Offline
Indianapolis, IN
Well, the upside to that is little or no oil consumption means a good tight engine. That explains the low soot.
The down side is that with no top off, comes no additives being bolstered either. In the case of the TBN, that could be a problem. You may not get much past 15-17k miles in that case.
Re: 2007 Cummins 6.7 Fedex Package Van [Re: dnewton3] #2155643
01/30/11 05:37 PM
01/30/11 05:37 PM
Carol Stream, IL
Carol Stream, IL
Well all in all I think the customer and I would be very pleased considering the hours on this oil, not only the miles.
This is far from scientific but probably on the low end in terms of actual hours on the oil.
In the past four months the truck operated 5 days a week for say 6 hours/day (this is probably a low figure). 30 hours a week for 4 months = 480 hours. During this time the mileage on the oil was 6575.
So using the 15K OCI figure here is what I come up with.
15,000/6575=2.28
2.28*480 hours=1094.4
If my customer can get 15K miles out of the oil and 1094 hours he should be very pleased. This is 1.82 times more than the spec of 600 hours for this oil.
Thanks for your input everyone!
Re: 2007 Cummins 6.7 Fedex Package Van [Re: filterdist] #2155646
01/30/11 05:44 PM
01/30/11 05:44 PM
MA
Santo Fontana Offline
MA
Is this what it looks like?
2016 GMC Sierra 5.3
Re: 2007 Cummins 6.7 Fedex Package Van [Re: Santo Fontana] #2155653
01/30/11 06:02 PM
01/30/11 06:02 PM
Carol Stream, IL
Carol Stream, IL
No it's a FedEx Ground unit. FedEx Express is a different division- company owned trucks. Looks more like this.
