2 stroke spark plugs
by Greaser73
07/17/18 04:13 PM
Upgrading From 1/2 in Impact Wrench.
by George7941
07/17/18 04:00 PM
Just Bought a Chromebook
by Al
07/17/18 03:55 PM
Purchased new Stihl weed wacker today
by tig1
07/17/18 03:53 PM
Castrol Magatec 5W30 $14.57 Better than Prime Day
by tenderloin
07/17/18 03:19 PM
Midair collision in Everglades
by pilottravis
07/17/18 02:54 PM
will they ever be a push back on car technology?
by edwardh1
07/17/18 02:53 PM
DeWalt Dce100 blower
by Fitter30
07/17/18 02:09 PM
Grits
by Walmill
07/17/18 01:59 PM
Getting rear ended worked out!
by 14Accent
07/17/18 01:42 PM
Article on the use of thin oils and why....
by racin4ds
07/17/18 01:08 PM
DOT 4 Brake Fluid
by maverickfhs
07/17/18 01:02 PM
Amazon Prime 20% off Magnatec Prime Day
by Datarock
07/17/18 12:57 PM
Cooper Adds Solarus to the Starfire Line
by UG_Passat
07/17/18 12:50 PM
Resuing mower oil!
by KMJ1992
07/17/18 12:19 PM
2015 Audi Q7 Transmission Service
by rooflessVW
07/17/18 11:58 AM
Curious Questions regarding Engine Wear
by mbacfp
07/17/18 11:42 AM
Bridgestone Driveguard worked as advertised!
by LeakySeals
07/17/18 11:30 AM
Renewable Lubricants Inc. Dexos 1 gen 2 SN plus?
by 2James1
07/17/18 10:52 AM
2017 VW -- mildly cold Air Conditioning
by BAJA_05
07/17/18 10:50 AM
RYCOJO, Gunplt, bjay, javylsu, Jlb27537
65503 Registered Users
85 registered (2012AccentSE, 77GrandPrix, 28oz, 2015_PSD, ad244, AandPDan, 5 invisible), 1640 Guests and 45 Spiders online.
65503 Members
67 Forums
287232 Topics
#2131440 - 01/07/11 10:19 PM 7.3L PSD UOA
sdan27 Offline
Loc: Michigan
This is the first UOA I've done on my truck using Polaris Labs. It came out pretty good as they usually do. In the past, I had some coolant getting into my oil from a leaking water pump dripping on a leaky pan gasket but that seems to be better. The engine has about 420,200 miles and the oil had about 10,300 miles. I used Service Pro 15w-40 with 2 quarts of Hot Shot's Secret which is where the Moly came from. The previous oil change, I used Schaeffer's 7000 with some of their Moly EP additive which is where I think the antimony came from.
Iron 32
Chrome 1
Ni 1
Al 2
Cop 8
Sil 5
Sod 3
Pot 5
Moly 45
Ant 19
Bor 25
Mag 913
Cal 1478
Phos 1031
Zn 1221
Soot <.1%
Water <.1%
Vis100c13.4
TBN 5.83
Ox 13
Nit 18
Even though it runs and starts good, I did a compression test a few weeks ago trying to figure out why my blowby and oil usage both seem high and my numbers were a little low, around 300 psi at each cylinder, so I was a little surprised that the nitration number wasn't higher. I used Delo 10w-30 this oil change because I've read here how well that grade works in HEUI engines and so far seems to be working real well. I used the Delo because we had a couple gallons around so I only needed a little for the oil change. If I use all the Delo up, I may switch to a Kendall 10w-30 I can get for a little less.
'94 F250 Powerstroke. LF9691 primary oil. AH1141 air filter. FS1282, FF5320 fuel filter. WF2071 coolant filter.
#2131481 - 01/07/11 10:50 PM Re: 7.3L PSD UOA [Re: sdan27]
DrDusty86 Offline
Loc: TX
Yea, the 300psi is low. Has it been worked hard and/or neglected in the past. I have run PSDs on the ranch since I was 13 and worked them REAL hard the 99' DRW 6spd had 331k when we sold it. It had 550psi, just a hint of blow by, but I used Rotella 5w40 after it had about 50k on the clock... Used wix air filters and greased the contact points... It used 1qt per 5k. THAT was a good truck, wish we still had it.. 420k that just breaking in a PSD.. Google Bill Hewitt or powerstroke help if you have questions. I actually called him a few times and he was great, very knowledgable.
Dusty
Edited by DrDusty86 (01/07/11 10:50 PM)
#2131529 - 01/07/11 11:33 PM Re: 7.3L PSD UOA [Re: sdan27]
chubbs1 Offline
Loc: Merritt Island FL, USA
are those original miles on the truck? that is an outstanding uoa i'm speechless.
'12 Charger SXT
QSUD 5w30 OEM filter
'12 Charger SXT
Edge FST EP 5w30 OEM (Mine;)
'11 Hyundai Sonata GLS
QSUD 5w20 OEM Filter
#2131555 - 01/08/11 12:02 AM Re: 7.3L PSD UOA [Re: sdan27]
sdan27 Offline
Loc: Michigan
I bought the truck used, with 160,000 miles back in Feb. of 2000. There was a period, somewhere around 300,000 when I had most the leaks fixed, etc. that it hardly used any oil. Since I've had it, I've used quality oil and either Wix/Napa filters or most recently ( last six years maybe ) Fleetguard filters and, other than the small amount of coolant I mentioned, I've always had good UOA results. Maybe its those cold Michigan winters taking their toll.
#2131625 - 01/08/11 04:33 AM Re: 7.3L PSD UOA [Re: sdan27]
dnewton3 Offline
Loc: Indianapolis, IN
Nice, boring UOA. Just the way you want it.
420k miles and still running. Gotta love that ol' 7.3P SD.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
#2132340 - 01/08/11 06:51 PM Re: 7.3L PSD UOA [Re: dnewton3]
motor_oil_madman Offline
Loc: Houston, Texas
Do you have a bypass setup on that engine?
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
#2133045 - 01/09/11 01:03 PM Re: 7.3L PSD UOA [Re: sdan27]
sdan27 Offline
Loc: Michigan
I used to run a Fleetguard LF777 bypass oil filter but I recently took it off. I also run an LF9691 venturi combo primary filter which has a bypass section built into it that has the same filter media as the LF777 does so I felt the seperate bypass filter was a little unnecessary, not that there's anything wrong with that.
Edited by sdan27 (01/09/11 01:05 PM)
#2133144 - 01/09/11 02:36 PM Re: 7.3L PSD UOA [Re: sdan27]
Loc: Houston, Texas
It's good to see someone buy a vehicle and then keep it for a long time and maintain it. It really pays off in the long run vs just trading it in every 3 or 4 years. When you take care of things you'll find that you'll avoid many problems down the line.
#2138945 - 01/15/11 01:31 AM Re: 7.3L PSD UOA [Re: motor_oil_madman]
Johnson615 Offline
Loc: Tn
What about lead or am I blind?
#2140240 - 01/16/11 11:26 AM Re: 7.3L PSD UOA [Re: sdan27]
sdan27 Offline
Loc: Michigan
Somehow I skipped that one. Lead was 4 ppm.
#2141647 - 01/17/11 05:11 PM Re: 7.3L PSD UOA [Re: dnewton3]
salesrep Offline
Loc: lllinois
+1
High quality Specialized Lubricants pay for themselves!
