I've read that all it takes to upgrade a 130-amp Ford 3G alternator to 160 amps is an upgraded rectifier. The stator coil does not need to be changed.
Does anyone know if that's true? If so, why? Is the upgraded rectifier causing less voltage drop so you get another 30 amps of output?
