I bought a Saturn L200 with the 2.2l engine and 4t40E transmission. It has 105,000 miles. So far, the trans shifts good, maybe slightly delayed shifts (shifts out of first at 3500 rpms) but I havent owned a 4 cylinder car since I was a teenager, so maybe thats normal.
Ive changed the fluid before in a 4t45E trans, so Im familiar with the check plug, and making sure the car is level, so on and so forth. With that being said -
What brand trans fluid are you forum members using with your 4t40E transmissions? Are you using synthetic trans fluid or conventional? Any suggestions?
