This is really a shot in the dark. Does anybody know what Dexter axle uses for bearing grease at the factory? I had to field service six hubs and could not completely clean out all the old grease. I am hoping the new grease is compatible with the factory blue stuff that Dexter used. I'm fairly certain that there won't be a problem, but if it wasn't for bad luck.......
