2 stroke spark plugs
by Greaser73
07/17/18 04:13 PM
Upgrading From 1/2 in Impact Wrench.
by George7941
07/17/18 04:00 PM
Just Bought a Chromebook
by Al
07/17/18 03:55 PM
Purchased new Stihl weed wacker today
by tig1
07/17/18 03:53 PM
Castrol Magatec 5W30 $14.57 Better than Prime Day
by tenderloin
07/17/18 03:19 PM
Midair collision in Everglades
by pilottravis
07/17/18 02:54 PM
will they ever be a push back on car technology?
by edwardh1
07/17/18 02:53 PM
DeWalt Dce100 blower
by Fitter30
07/17/18 02:09 PM
Grits
by Walmill
07/17/18 01:59 PM
Getting rear ended worked out!
by 14Accent
07/17/18 01:42 PM
Article on the use of thin oils and why....
by racin4ds
07/17/18 01:08 PM
DOT 4 Brake Fluid
by maverickfhs
07/17/18 01:02 PM
Amazon Prime 20% off Magnatec Prime Day
by Datarock
07/17/18 12:57 PM
Cooper Adds Solarus to the Starfire Line
by UG_Passat
07/17/18 12:50 PM
Resuing mower oil!
by KMJ1992
07/17/18 12:19 PM
2015 Audi Q7 Transmission Service
by rooflessVW
07/17/18 11:58 AM
Curious Questions regarding Engine Wear
by mbacfp
07/17/18 11:42 AM
Bridgestone Driveguard worked as advertised!
by LeakySeals
07/17/18 11:30 AM
Renewable Lubricants Inc. Dexos 1 gen 2 SN plus?
by 2James1
07/17/18 10:52 AM
2017 VW -- mildly cold Air Conditioning
by BAJA_05
07/17/18 10:50 AM
RYCOJO, Gunplt, bjay, javylsu, Jlb27537
65503 Registered Users
85 registered (2012AccentSE, 77GrandPrix, 28oz, 2015_PSD, ad244, AandPDan, 5 invisible), 1640 Guests and 45 Spiders online.
65503 Members
67 Forums
287232 Topics
#2126129 - 01/03/11 07:08 PM Cat C-13 with Luberfiner LFP 9750 Bypass Filter
Johnson615 Offline
Loc: Tn
Install the Luberfiner LFP 9750 filter and LMB-451 base. This hole report posted is with bypass filter installed. The wear looks good but I cant understand why the TBN is up and down? Probably will extend drain intervals as much as the oil will allow. This current oil is Chevron Ursa 15w40. We buy it in bulk and we are very pleased with this oil but the TBN doesnt make sense. I know if we bought a higher quality oil we really could extend intervals but its not practical to use ase we use this oil in all of our fleet from earth moving equipment to diesel pickups.
Sorry this engine is in a KW Dump truck that work within a 100 mile radius. It is about 50/50 highway driving and stop and go traffic
#2126148 - 01/03/11 07:23 PM Re: Cat C-13 with Luberfiner LFP 9750 Bypass Filter [Re: Johnson615]
LargeCarManX2 Offline
Loc: Up here in the NorthWest
Sample # 4 is most likely an error. The TBN is in great shape. Most likely a marginal error or allowable plus or minus margin.
I have a few questions:
Total capacity with the Luberfiner bypass and fullflow is 13 gallons?
Why are you sampling every thousand or so miles?
Are you doing the UOA or is a company?
"Success is the ability to go from one failure to another with no loss of enthusiasm."
Sir Winston Churchill
#2126164 - 01/03/11 07:33 PM Re: Cat C-13 with Luberfiner LFP 9750 Bypass Filter [Re: LargeCarManX2]
Johnson615 Offline
Loc: Tn
Well im going by memory but our C13 hold 10 gal and the bypass setup adds 1 gal.
I am posting this for fyi only really. There has been some questions about this setup. Its a cheap bypass setup compared to others about $30 for the base the about $30 for filter through out luberfiner account.
We sample them and send to polaris
#2126173 - 01/03/11 07:42 PM Re: Cat C-13 with Luberfiner LFP 9750 Bypass Filter [Re: Johnson615]
I personally would sample around 7K and then work the UOA upwards towards a higher UOA. A safe TBN region such as 1.0 TBN and 20 to 30 in oxid and nitration numbers should be fine. If your fuel dilution, soot, and viscosity stay within Cats allowables....keep bumping upwards towards 12-15K between oil changes for a city/highway engine. The goal would be to find your safe threshold for changing the oil. Then at each oil change send in a sample to keep an eye on the engine.
Edited by LargeCarManX2 (01/03/11 07:45 PM)
Edit Reason: fixfoopau
#2126191 - 01/03/11 08:06 PM Re: Cat C-13 with Luberfiner LFP 9750 Bypass Filter [Re: Johnson615]
You know looking back at sample # 8 the following or Cat's protocol might need to be looked at. The viscosity has not been harmed, however...lubrosity can/could be effected:
Depending on application, for diesel engines, a cautionary limit is typically set at around 1.5% dilution (about -20 C flash) and a critical limit at 3% to 5% dilution (-40 C to -60 C flash). Application-specific calibration curves based on the actual test protocol (open cup, closed cup, etc.), motor oil brand/grade, and fuel type, will greatly improve precision in translating a drop in flash point to percent fuel dilution.
We will need some of the pro's to chime in at this point!!!!
#2126331 - 01/03/11 09:59 PM Re: Cat C-13 with Luberfiner LFP 9750 Bypass Filter [Re: Johnson615]
sdan27 Offline
Loc: Michigan
Could the TBN be going up from topping up the oil level in the sump from oil usage?
'94 F250 Powerstroke. LF9691 primary oil. AH1141 air filter. FS1282, FF5320 fuel filter. WF2071 coolant filter.
#2131811 - 01/08/11 09:57 AM Re: Cat C-13 with Luberfiner LFP 9750 Bypass Filter [Re: Johnson615]
I would like too see this one keep going .....
BUMP!
#2133148 - 01/09/11 02:43 PM Re: Cat C-13 with Luberfiner LFP 9750 Bypass Filter [Re: LargeCarManX2]
motor_oil_madman Offline
Loc: Houston, Texas
I had them mess up a uoa one time. They gave me a TBN of like 7.8 and I knew that wasn't right because the oil only had a tbn of like 8 to begin with. I called them up and they retested it and corrected it.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
