Originally Posted By: Bror Jace
The flaw is that many XW-30 PCMOs will shear rapidly under the stress that an air-cooled engine sees. As they shear and thin out, they tend to get past the rings and are consumed. If the engine runs out of oil, it will likely seize (I saw this happen to a brand new water pump many years ago).
Conventional or synthetic in a mass-market PCMO is not likely to make a difference.
A good synthetic oil shouldn't have many VIIs to shear, right? I think that is also why they also recommend SAE 30 at high temperatures - That is what I use.
So I gather your beef is with them okaying synthetic 5w30 at high temps? I guess I can see that. No real need for it, although I don't know what would make it shear down and burn in your water pump engine if it was a quality synthetic and not loaded with VIIs.
