One of the cars i'm in charge of maintaining is a 03 Lancer Automatic that uses SP III fluid for the ATF, its just shy of 70k now. Bought it brand new, I did a drain and fill at 40 and 60k.
Here is the thing, i noticed it slipping somewhere around 35k, its not slipping bad by any means. The driver never notices it but i do when in the car. Its slips when shifting 1-2 around 20mph, the revs only go up to about 2700rpm and back to normal. It happens random and from the times i've been in the car about once every 2-3 weeks.
The fluid color when i drained it wasn't burn or black but darker then what i'm used to and someone on here told me thats the nature of SPIII fluid.
Anyone have a solution to this? Or is this one those odd things that are meant to happen... I wanted to change to amsoil fluid but i read/heard these trannies are picky on fluid
