Could I get away with just Molybdenum and Lithium Wheel Bearing Grease?
yes you can but in those cases, water will wash it out over time. I have many mechanics that use ours and of course standard greases on this area of the brakes.quote:
BMW carries little packets of the stuff, just ask and they'll give you a few.quote:
Originally posted by moribundman:
Plastilube is an excellent high temperature grease that works on brake calipers and also as anti-squeal. It's acid and copper free and it won't wash off. You may be able to get it from a BMW service department or at gun shops (Plastilube is used on guns).
No real silicone is going to swell internal brake parts. I wouldn't be surprised if the O-rings in caliper slides are formulated to withstand hydrocarbons. I will let somebody else find out. As long as your silicone has a high enough temperature rating, it should be fine on any brake parts.quote:
Originally posted by prebis:
I have a big tube of silicon grease I bought at the pool supply store. Can I use this on my brakes?
Best deal? I forget what I paid NAPA for a 4 oz. tube of Sil Glyde, but if it was more than $8.50, I think I would have remembered.quote:
Originally posted by TxGreaseMonkey:
Use Motorcraft Silicone Brake Caliper Grease and Dielectric Compound (XG-3-A) or Squeak Relief Caliper Grease (silicone grease and moly). Best deal is to purchase a 3 oz. tube of the Motorcraft product from your local Ford dealer for around $8.50. Tons of applications for silicone grease.
