Ive noted rough running, spongy throttle, sag, backfiring like a bad plug/ out of tune but I think a more advanced ECU will pull timing and then try to advance constantly which can cause an engine roll of high periodicity. Around here you are lucky if you get reported octane and decent fuel, its usually barely adequate to get around on, never mind get any performance or approach stated horsepower and torque. When this happens over more than 2 tanks I do sometime add 1 or 2 gal of 93 to a tank and performance improves. I ve noted real euro syn (like motul 8100 econergy) make fuel quality transparent - cleaner ring stack I would assume.
