BMW Tire Rotation
USA - Florida
My wife's Z4 has the same size tires on the front and back. The dealer told her she should not rotate her tires. They carry slightly different pressure (32/35) ... if she rotates now she can probably go another year or two w/o new tires. If she waits she will need new tires on the back soon ... They are run flat tires w/ the low pressure warning system .... am I wrong in thinking rotating these tires would be a good idea ?
Thank you for any and all input ...
I really don't see why you couldn't rotate them. They're probably directional tires, so just swap them front to back. If the TPMS is like my mother's BMW, it uses the ABS sensors to sense different rotation speeds, so it shouldn't throw any warning lights.
The reason BMW typically advises against tire rotation is that often times rear alignment has some negative camber which causes uneven wear on back tires. If you put those tires on the front, you may experience less than perfect handling (may not be of any concern to some), plus they may become noisy.
But if your rears are worn evenly, then I think I'd attempt rotating them and see what happens. If you don't like it, you can always rotate them right back.
I rotate the tires on mine, but my alignment has been adjusted slightly so that the negative camber is only very slight.
Originally Posted By: BobFout
Rather than relying on what the dealer says, what does the owner's manual say?
+1
I read that to maintain maximum performance BMW recommended rotating tires every 3,000 miles. BMW figured that the cost of doing that would would be prohibitive for a daily driver, hence don't bother. They said it takes several thousands of miles for rotated tires to adjust to the new position and during that time a decrease in cornering performance would be evident. Unless you need racing performance, I would rotate every 7-10K miles or so in a RWD recomendation or if anything is in the owners manual, I would folow that.
Absolutely nothing.
I agree. Also, staggered wheel set-up is fairly common especially on sport package equipped bmw's. I think they say no tire rotation is recommended also for this reason.
My BMW had the same tire/wheel size front/rear and I found the outside edge on the front would wear a little more (not too bad) and the inside edge on the rears would wear due to a little negative camber as well as the center of the tread would wear due to a happy accelerator pedal. Switching fronts to rears and vice-versa helped ensure I got mostly all the tread from a set of tires. I wouldn't hesitate to do it in your situation.
Higher Rear neg camber isn't a reason why you should not rotate the tires, because most cars these days have the rear cambers more negative than the front. If you rotate them too late... then rotating them up front don't so squat.
Originally Posted By: Trajan
What QP said.
I don't bother, due to staggered sizes.
It's due to the staggerred sizes. If they are directional tires, then you cannot rotate at all.
If the tread is assymetric, you can rotate them side to side.
But the OP does not have a staggered setup:
BMW's stance is not to rotate, regardless if you have a staggered setup or not.
Ignore what they say, if you have same size front/back, just rotate as much as you like front/back. If your tire is not directional, rotate any way you like. Just make sure to adjust tire pressure afterward and do it frequently, and all is well.
I missed the OP saying that part. BMW's stance is because most owners are suckered into buying new tires all the time, due to uneven front to rear wear.
the camber is [censored], because VW recommends tire rotation on my Passat, even though the front camber is about -0.5 degress and the rear camber is -1.5 degrees. However, the tire rotations coincide with the 10,000 mile oil change interval-- which is way too long of an interval
I have an E39. I used to rotate. Even representatives from the tire manufacturers told me to rotate as long as I do it often. I would rotate every 2,000mi or so since it was easy for me to do.
Two things made me stop rotating:
1/ The E39 forum where I participate has a member who moved to Europe from the US. He shares nuggets of wisdom about how things are different "over there". One of the things he pointed out was that NO ONE rotates their tires (at least on BMWs) in Europe because they cause strange high speed handling and stability problems.
2/ I was always chasing quirkly little handling and stability problems. They weren't major, but I noticed and it bugged me. One time I was doing a routine rotation on my summer tires (Toyo T1R at the time) and I was rotating back into the positions they were in when I first put them on the car. Yes, I properly set the pressures back to exactly the same F/R pressures and splits as before I rotated. I felt an immediately change in the car - improved turn in, faster steering response and better stability. It was as if I had an alignment problem fixed or upgraded some component in the suspension.
Between these two points, I was sold. The manufacturer knows what they're talking about and I'm not going to second guess them any longer. Others have provided proof (all of Europe, apparently) and I've witnessed it firsthand at North American speeds. I won't be rotating tires on any BMW again. I'm now on a new set of tires (Michelin PS2s) and they haven't "gone off" or developed any quirky issues in the two seasons I've run them.
I know everyone won't agree, but I'm sold... If you bought a BMW for handling, stability, performance, etc.... don't rotate IMO. Maintain the car to get the most from your tires - keep your alignment in order, watch for wearing bushings and balljoints, watch your tire pressures - and replace them when needed. Some people will dial the rear camber to the most neutral allowed by the spec (instead of the center of the range) to extend rear tire life.
Well it's not like this causes them to have to buy more tires. They just buy them two at a time, not 4 at a time.
I'd rotate at the end of the tire lifecycle if it extends the usefulness of a set thru summer, since the traction demands then are lower and wear rate is much higher from the hot pavement.
Generally, I prefer better tires on the front, fwiw.
As Craig pointed out, the reason BMW does not recommend rotating tires is due to the adverse change in handling that occurs. But that change is primarily due to the high camber BMW builds in their cars - and that camber causes irregular wear. If the camber were more like normal, BMW's wouldn't handle so well, but they would get even wear. BMW doesn't care a hoot about tire wear = particularly since they don't have a warranty on tires.
No one warranties tire wear. The tire manufacturers warranty against defects (unaffected by alignment), and the car companies (including BMW) sometimes offer tire replacement warranties at additional cost. And even if anyone did warranty tire wear, your statement would be backwards.
On the larger point, of course BMW is more willing than other companies to sacrifice tire wear for handling. That's sort of the point of their cars and their market, isn't it?
Thanks for pointing that out. It's the first compelling reason I've heard not to rotate. Point #1 isn't that persuasive but more interesting, but point #2 is illustrative and something I'd like to hear more about. Never heard this one before.
I'd love to find out BMW's rationale. Interesting!
Well, in a lot of ways my point #1 should be almost as compelling as my point #2. In Europe, no one even thinks of rotating because they notice weird handling issues when they do. My observation #2 was simply a personal observation of the same issues documented by the Europeans. It's all the same thing. When this person had discussions in his car enthusiast circles/clubs about tire rotation he was greeted with a "Why on earth would you do that? We never do that because...." response. Yes, it's 2nd, 3rd and 4th hand information but that doesn't invalidate the principal point being made by those who said it.
With the higher speeds typical in Europe, and what I've observed to be a "different" approach to driving, it's neither considered safe nor tolerable to live with the "weirdness" just to allow rotation.
As someone else here pointed out, you may replace a typical BMWs rears before the fronts by not rotating, but it typically works out in the end (depending on the car, options, alignment and driver) just not 4 tires at a time.
As d00df00d says it's BMW's intent to promote handling, stability and that German "planted" feeling with the factory setup. Tire rotation works against those traits. Some may disagree, but in theory you are getting something "in exchange" for the increased camber and associated wear. I'm sure some readers will call it a "design flaw" but the factory alignment settings are there for a reason - not just a conspiracy theory to sell more tires. It doesn't change the truth that "those dang German cars wear out rear tires fast" but it's not a mystery why it happens. Through a V8, V10 or V12 into the mix with that alignment and it happens faster
Myself, I bought a BMW for the handling, planted, agility despite size/weight etc...etc... so, after reading and seeing firsthand that even extremely frequent rotation negatively affects these characteristics, I'll just live with replacing pairs of tires out of sync.
