Yes, it is a very interesting subject as it is an area that is very important but less looked upon when discussing lubrication in general.
George, the main thing I wanted to do was look at some of the technical #'s. Interesting enough, even though moly is an issue, reversability is also very important and what is bothersome is that many greases when heated up such as the lithium complex, will seperate not allowing the oil to mix back in thus seperate and lose it's ability to maintain proper lubrication. I know you stated you use the exact same grease without the moly, but question is, just how exact is the two in comparision to both tech data sheets.?
IMO, I'd be looking at other areas other than just the moly side of the grease, reversability being one of them as well as temp's and such. I'd very interested in seeing the tech sheets on the one with moly and the one that is working without moly so to compare in what differences you incurred by switching,as I suspect you'll see there has to be some variances between the two other than just the moly.
