If you can do it, by all means go for it. Truth is if you have the head off you might as well clean up the valves, check the guides replace the seals, and hope the lower end of the engine is in good shape. LOL.
I've taken on those projects over the years, I guess it depends on experience level, cash on hand, and motivation. Lately I have very little motivation and cash on hand. LOL
I know that`s a gamble just doing the head. As it may have oil consumption after wards. But at least soak it,check everything out,and maybe put in new bearings on the bottom end. I had to replace the head on a 1984 Oldsmobile Firenza. It had the 1.8l motor that was always cracking heads (until I made the fan stay on,that cured that) Any way,I replaced the head @ around 118,000 miles,didnt touch the bottom end,and lucked out. It ran great.
