FYI, the term "G80" is a RPO (Regular Production Option) number, not a type of traction aid. Over the past 30 years, it could be a plate type limited slip (Saginaw, Eaton) and cone clutch type limited slip (Borg warner/Auburn Gear) or the so-called "Gov-Lok," more correctly called the Eaton Locking Differential (it isn't really a true locker because it can be made to bias when it's ostensibly locked, but I digress). I believe GM has also started using the gear type AA (American Axle) limited slip as well in some recent applications.
In trucks, it's generally the Eaton "Locker" but S10s could have a plate type limited slip, as well as cars. The Eaton Locker doesn't need any special additive but the plate type limited slips may. As I said before, many synthetics have the friction characteristics necessary so as to not need a special additive.
By the way, Egghaus, you did not tell us what truck you have. Might have some bearing on "the case."
