Hey all,
Been a long time since I visited this site.
I recently acquired a 1997 Polaris Indy 500 (carb, not EFI) that's in remarkable shape. The previous owner had used nothing but genuine Polaris oil in it since new. It now has about 5000 miles on it, and still pops 125# in both cylinders.
A good buddy of mine is really into snowmobiling and also is an avid Polaris rider. He owns an automotive machine/speed shop and is a distributor for Schaeffer's oil. He's been using the Schaeffer's #706 Supreme 7000 2-stroke TC-W3 oil in his sleds for a good number of years now and has absolutely no problems with it. He strongly recommended I use this oil instead of the Polaris oil that it's been running since new. I trust his opinion and know that he's not going to recommend a product until he's thoroughly tested it first. The one thing that concerns me is that I looked up the Technical Data Sheet on this oil and it specifically states NOT to use it in any 2-cycle application that has rotary valves or power valves, which his newer sleds all have. It's very interesting to me that this specific topic came up when reading that TD sheet, because that's the main thing he commented on when recommending this oil...He said that compared to the Amsoil Interceptor oil he was running previously (in a 2005 XC SP 800), the power valves stayed perfectly clean on Schaeffer's, but got "gummy" on Amsoil. He also commented that plug cleanliness was greatly improved, as was smoke levels when switching to Schaeffer's.
Is he actually doing his engines a disservice by using this oil? He's not had one failure whatsoever and he's not the average rider. 90 MPH is his "cruising" speed. I won't even ride with him because he's that much of a maniac out there! His latest sleds (he's got 2 right now) are a '08 Polaris Dragon turbo, and an '09 Arctic Cat F1000 Sno Pro. The Dragon, being a 4-stroke, he's running Schaeffer's 5w40 Supreme 9000 full synthetic, and the F1000 runs Schaeffer's 2-stroke TC-W3. Not one problem with either sled.
I trust his experience enough to run this oil with confidence, but based on what I've been reading here, it seems like it's really not the right oil for this application.
For my sled, not having power valves, and being a considerably lower output engine, I can't see this oil causing me any trouble, but I'd just like a little bit of additional input on the subject.
I've been using Schaeffer oils in my cars and trucks for a great number of years now, and they've always been great.
Any thoughts would be greatly appreciated.
