2010 Volkswagen 2.0L Turbo CR(TDI) Factory fill
NJ
2010 Volkswagen 2.0L Turbo CR (TDI)
Replaced Factory Fill. 1st Oil Change @ recommended 10K miles.
MI/HR on Oil - 9,963 Miles
MI/HR on Unit - 9,963 Miles
Make Up Oil Added - 0 qts
MAESURED/UNIV AVG
ALUMINUM - 174 / 6
CHROMIUM - 4 / 1
IRON - 80 / 39
COPPER - 24 / 5
LEAD - 1 / 4
TIN - 0 / 1
MOLYBDENUM - 5 / 9
NICKEL - 1 / 2
MANGANESE - 7 / 1
SILVER - 0 / 0
TITANIUM - 2 / 0
POTASSIUM -469 / 7
BORON - 5 / 34
SILICON - 20 / 5
SODIUM - 7 / 7
CALCIUM - 1364 /1904
MAGNESIUM - 13 / 225
PHOSPHORUS-673 / 847
ZINC - 768 /1011
BARIUM - 1 / 0
SUS Viscosity @ 210*F - 63.7
cSt Viscosity @ 100*C - 11.24
Flashpoint in *F - 415 SHOULD BE > 415
Fuel % - TRACE < 2.0
Antifreeze - 0.0
Water % - 0.0
Insolubles - 0.2 SHOULD BE < 0.6
TBN - 3.2
Blackstone Comments: The high wear and silicon are common finds in new engines. The excess wear is from new parts breaking while silicon comes from sealers used during assembly. Both should improve with subsequent oil changes. Universal averages for the 2.0L TDI are based on an oil run of 6,500 miles. This oil was run a lot longer, so that also contributed to the wear. Fuel at trace level isn't a problem and the TBN was strong at 3.2, so lots of active additive was left. 1.0 is too low. Stay with a 10,000 mile oil run for now. Once wear and silicon settle down, we'll suggest going longer.
There are other UOAs of factory fill common-rail TDI's on here and on TDIclub.com. Other than the aluminum, looks pretty normal for recent TDI FF. 174 is high aluminum even for factory fill though. I wouldn't panic yet though, see if it comes down in the next OCI.
Hi,
Bob - You are correct - as well, many people also think that Alusil construction may shed some aluminium and/or silicon.
IME with Porsche engines I have not seen this - not to say of course that it cannot/does not happen
Originally Posted By: BobFout
Originally Posted By: Audi Junkie
Runaway aluminum.
Brand new engine.
Originally Posted By: Doug Hillary
Hi,
Gents, Thanks for the feedback. I'll post the next UOA. I may have one done @15K. BTW, replaced FF w/Lubro Moly Top Tec 4200.
Potassium at 469? Ours has been in the 50ppm range, and blackstone believes it is indicative of a coolant leak. Yet on yours, they have 0.0 in antifreeze column. They don't test for glycol, so it seems their antifreeze % is highly subjective. Granted our coolant does disappear very very slowly to some unknown place and this was mentioned on the oil slip.
For some reason VAG uses a factory fill oil that contains potassium. Don't know why but it's in all the used-oil test samples. So nothing to worry about there.
I would suggest not bothering with another used-oil test until 30k miles. All the wear metals should be much reduced and you might consider that test as a baseline for later testing at 60k miles and again at 100k miles.
Runaway aluminum.
Brand new engine.
Diagnosis FAIL. It is the FF. Now for the next change watch and see that Al hit universal averages because the FF was run as recommended by the designers and engineers of the engine.
Just to mention that the high levels of potassium are in the VIRGIN oil samples too.
2010 Volkswagen Golf 2.0L Turbo CR (TDI), CJAA engine code.
Replaced 3rd Fill. (Lubro Moly TopTec 4200, used B2-B5 w/OptiLube). Dealer refilled with Castrol.
Note: I Changed the oil early since I was at the dealer and wanted a UOA on the LubroMoly. Wanted to see the fuel in oil results since I use biodiesel (B2 toB5). This car is driven in the CA desert. High temps and very low humidity, so assume that D2 evaporates from the crackcase a little easier than in other parts of the country.
MI/HR on Oil - 9,963 Miles ** 7,999
MI/HR on Car- 9,963 Miles * 25,489
Noted that Blackstones univeral averages have been adjusted (mainly downward)
Measured/Univeral Averages *MEASURED (25,489 Miles)/Univeral Averages
ALUMINUM ---- 174 / 6 ****** 30 / 20
**Aluminum: Pistons, piston pin plugs, bearings, and the case (fretting).
CHROMIUM ------- 4 / 1 ******* 2 / 1
**Chromium: Rings, (replacement) cylinders, a trace element in steel.
IRON ------------ 80 / 39 ***** 72 / 43
**Iron: Cylinders, rotating shafts, the valve train, and any steel part sharing the oil.
COPPER --------- 24 / 5 ******* 9 / 8
**Copper:Brass or bronze parts, bushings, bearings, and oil coolers.
LEAD ------------- 1 / 4 ******* 0 / 1
**Lead: Primarily leaded gas blow-by, (traces from) bearings.
TIN --------------- 0 / 1 ******* 0 / 1
**Tin: Bearings, bronze parts (with copper), anti-wear coatings.
MOLYBDENUM --- 5 / 9 ******* 6 / 17
**Molybdenum: Traces of anti-wear coatings, some cylinder types.
NICKEL ----------- 1 / 2 ******* 1 / 1
**Nickel:Valve guides, trace element in steel.
MANGANESE ----- 7 / 1 ******* 2 / 1
**Manganese:Grease additive.
SILVER ----------- 0 / 0 ******* 0 / 0
**Silver:Trace element in some types of bearings.
TITANIUM -------- 2 / 0 ******* 0 / 1
**Titanium:Trace element.
POTASSIUM --- 469 / 7 ****** 59 / 33
**Potassium:Trace element.
BORON ----------- 5 / 34 ***** 27 / 18
**Boron:Trace element.
SILICON -------- 20 / 5 ******* 6 / 5
**Silicon:Abrasive dirt (via intake air), silicone sealers, gaskets, and lubes.
SODIUM ---------- 7 / 7 ******* 2 / 4
**Sodium:Contamination common to antifreeze and brine-filled valves.
CALCIUM ----- 1364 /1904 **1424 / 1425
**Calcium:An additive usually only found when CamGuard is being used.
MAGNESIUM ---- 13 / 225 **** 11 / 29
**Magnesium:Oil additive, rare in aircraft engine oils.
PHOSPHORUS - 673 / 847 *** 583 / 734
**Phosphorus:Common additive in aircraft oils.
ZINC ----------- 768 /1011*** 695 / 861
**Zinc:Component of brass (with copper), oil additive common to auto engine oils.
BARIUM ---------- 1 / 0 ******* 0 / 0
**Barium:Additive used in some synthetic oil, not common in aircraft oil.
SUS Viscosity @ 210*F - 63.7 ** 63.5
cSt Viscosity @ 100*C - 11.24 ** 11.19
Flashpoint in *F - 415 ** 415 SHOULD BE > 415
Fuel % - TRACE ** TRACE SHOULD BE < 2.0
Antifreeze - 0.0 ** 0.0
Water % - 0.0 *** 0.0
Insolubles - 0.2 ** 0.3 SHOULD BE < 0.6
TBN - 3.2(FACTORY OIL) ** 2.9(LubroMoly TopTec 4200)
@ 9,963 Miles; "The high wear and silicon are common finds in new engines. The excess wear is from new parts breaking while silicon comes from sealers used during assembly. Both should improve with subsequent oil changes. Universal averages for the 2.0L TDI are based on an oil run of 6,500 miles. This oil was run a lot longer, so that also contributed to the wear. Fuel at trace level isn't a problem and the TBN was strong at 3.2, so lots of active additive was left. 1.0 is too low. Stay with a 10,000 mile oil run for now. Once wear and silicon settle down, we'll suggest going longer".
@25,489; "This engine has made some nice improvements since the first time we saw it. Aluminum iron, copper and silicon have all improved enough that they're all in the average range. That's not to say they're "perfect" here, because aluminum could certainly stand to come down a little more (and so could iron), but it sounds like you're taking good care of this engine so improvements should come with time. A trace of fuel is no concern at all. The TBN read 2.9, so there's still active additive left. Try an oil run of 9,000 miles next time. Nice progress!"
3rd UOA Castrol SLX Professional LL03 5W/30. Note I did not UOA the 2nd oil change.
