So I've looked at a couple Cherokee Sports this past week, and both had brown transmission fluid, which I've never seen before. I poked around on the internet, and Chrysler TSB 21-014-07 says ATF+4 turns brown:
Quote:
Mopar ATF+4(R) has exceptional durability. However, the red dye used in ATF+4(R) is not permanent; as the fluid ages it may become darker or appear brown in color. ATF+4(R) also has a unique odor that may change with age. With ATF+4(R) fluid, color and odor are no longer indicators of fluid condition and do not necessarily support a fluid change.
The Sport I looked at today is a 2000 with 148k on it; the ATF was brown, but it looked clean. Is that sufficient to consider the trans OK?
