I have a Whacker brand generator with a Honda 11 hp on it. I have 4 generators and I try to rotate them when I go camping to give them some use. I havent used the Honda in awhile, probaly 6 months. I store it with a full tank and stabilizers in the gas. I took it last outing and when I started it, it started smoking white smoke, now a dont mean a little smoke, full white smoke stream coming out the exhaust outlet for about 30seconds to a minute. I was ready to shut it down and it just cleared up and ran fine, ran all night without a problem. Went out the next day started it, first pull and it did the same thing, thick cloud of white smoke, full on now blowing solid stream, then it stops and runs fine, no smoke. I pulled it out today and although it has alot of compression and will yank my hand back, it started right up, 1st good yank and it smoked like crazy and ran fine. This is like everytime now, but what would cause that. Its not worth and tear down, but it sounds good. Checked the oil level, its good, not too high. I cant believe the amount of smoke it puts out on startup though, thick white smoke and alot of it-weird.
