Hi Guys,
Here are my number and the analysis:
TERRY: Wear was generally above average in the first sample from your TDI. Aluminum comes from the
pistons, while iron is from a steel part, such as the cylinders. Potassium was high as well, and may show a
coolant problem developing. If that's the case, it's slight but it could be enough to cause the excess wear
that we found. We have also seen potassium in this type of engine be the charge air cooler or EGR, and if
that's the case it's not a problem. Suggest keeping your oil changes short for now (~7,000 miles), to limit
metals, which make the oil abrasive & check back.
Aluminum 24
Chromium 2
Iron 60
Copper 7
Lead 0
Tin 2
Moly 3
Nickel 1
Mang 1
Silver 0
Titanium 0
Potasium 57
Boron 1
Silicon 5
Sodium 1
Calcium 1674
Mag 7
Phosphorus 616
Zinc 719
Barium 0
anitfreeze positive.
I am a little bummed. The factory recommended oil and oil change recommendations are causing high wear and i have coolant in my oil. Not good. I am going to change at 5000 and check back.
Anyone else have oil analysis results?
Terry
Aluminum 24
Chromium 2
Iron 60
Copper 7
Lead 0
Tin 2
Moly 3
Nickel 1
Mang 1
Silver 0
Titanium 0
Potasium 57
Boron 1
Silicon 5
Sodium 1
Calcium 1674
Mag 7
Phosphorus 616
Zinc 719
Barium 0
Terry
