I took an oil sample from the Cummins L10 engine in our Case IH 9250 tractor. The tractor has 6410 hours with 404 hours on the oil. I did an in-frame overhaul on the engine a couple years ago so it probably only has about 1000 hours since then. The tractor does a lot of heavy field work, especially this time of year pulling the subsoiler and chisel plow. We're using Service Pro 15w-40 and everything looked good except the nitration was high. Should I worry about that if all other numbers were good?
Iron 31
Al 2
Cu 1
Lead 8
Sili 5
Sod 4
Moly 132
Bor 20
Mag 985
Cal 1513
Phos 1071
Zn 1247
Fuel Soot .3%
Vis 100 C 14.6
TBN 5.56
Oxid 19
Nit 26
Iron 31
Al 2
Cu 1
Lead 8
Sili 5
Sod 4
Moly 132
Bor 20
Mag 985
Cal 1513
Phos 1071
Zn 1247
Fuel Soot .3%
Vis 100 C 14.6
TBN 5.56
Oxid 19
Nit 26
