than the rest of the tires.
Factory OEM 225/40/18, manufactured 44th week of 07 with 31k miles life, on IS250 RWD Front axles. This seems to be a common problem on this car due to the factory "toe out" alignment spec. I am wondering other than going to a racing alignment shop that will do a more precise / neutral toe alignment, and get new tires. What else should I do to prevent this from happening again?
Was thinking about "flipping" the tires inside out, but I'd imagine most reputable tire shops won't take the chance of blow out and get sued, and the gain in life is negligible.
I am not sure if a franchise will go "out of factory spec" for me to make the tire life longer.
