I have a 2000 Honda Accord 4 cyl with an automatic transmission. It has just over 155,000 miles and I am the original owner. All required maintenance has been done.
Recently the transmission has been shifting hard and hesitating during acceleration. This is a new problem, not a long term one. My first thought was to add a bottle of the transmission fix stuff sold in the auto parts store to see if that would give me a cheap and fast fix. But it says not to overfill and my fluid is already full, and I don't know how to drain any fluid. And I am too old to get under the car and do it. So is this stuff safe and will a 12 ounce bottle overfill the transmission? What brand is good?
My second thought was to get the transmission fluid drained, add new fluid and a bottle of this stuff to see if it makes any difference. I have read the other posts where Honda recommends three fluid drains.
I doubt a fluid drain and fill without the additive would help at all with the problem. But I don't know if these additives are safe and effective.
What would you recommend? And, if I do the flush and fill and add the additive, what transmission fluid would be best for my problem?
I want to avoid major transmission work and am hoping this is easily fixable.
Thanks
Thanks
