Hi,
ZeeOSix - Lubrication systems and their operation are never a one size fits all - variations are immense. Fluid dynamics are primarily a constant in principle and practice
Several years ago after a debate on the subject a Californian tuning shop used an engine dyno to track oil temp and pressure in relation to the 9bar system bypass. The engine was a Porsche V8 and the lubricant was M1 15W-50 which has great flow characteristics
It was found that it took around five minutes from ambient OT to dislodge the relief valve at around the engine's design OP parameter of 4krpm (5bar). The oil temp was then at around 95C IIRC. The bypass returns oil directly to the sump ex the pump. You can imagine in this case that very little (volume) lubricant would be flowing through the media. The FF filter had a media bypass setting of 2.2bar
