Not a great report in my opinion. TBN seens very low for a short amount of time. 50/50 Highway and city driving.
Silicon has actually increased a bit after a shorter oil change interval than what we saw last time, so we
suggest inspecting your engine's air filtration system for leaks. Wear has improved, so we can't call the above average
copper and lead a problem in this report. The flashpoint test found a trace of fuel, which is not a problem level and
should disappear next time. The viscosity was fine for a 5W/30 oil. The TBN showed some active additive remaining at
2.6. Continue running about 4,000 miles on the oil while we keep an eye on the excess wear levels. Caution
Miles on oil- 4018 miles
Miles on unit- 82,854
Make up oil- 0 quarts
ALUMINUM 0
CHROMIUM 2
IRON 5
COPPER 42
LEAD 15
TIN 1
MOLYBDENUM 93
NICKEL 1
SILVER 0
TITANIUM 0
POTASSIUM 1
BORON 13
SILICON 26
SODIUM 9
CALCIUM 2799
MAGNESIUM 148
PHOSPHORUS 617
ZINC 740
BARIUM 0
cSt Viscosity @ 100°C 57.8
SUS Viscosity @ 210°F 9.58
Flashpoint in °F 365
Fuel % TR
Antifreeze % 0.0
Water % 0.0
Insolubles % 0.2
TBN 2.6
TAN
ISO Code
My air filter is pretty new so my assumption for the high silicon reading is a leak from the intake manifold gasket.
ALUMINUM 0
CHROMIUM 2
IRON 5
COPPER 42
LEAD 15
TIN 1
MOLYBDENUM 93
NICKEL 1
SILVER 0
TITANIUM 0
POTASSIUM 1
BORON 13
SILICON 26
SODIUM 9
CALCIUM 2799
MAGNESIUM 148
PHOSPHORUS 617
ZINC 740
BARIUM 0
Fuel % TR
Antifreeze % 0.0
Water % 0.0
Insolubles % 0.2
TBN 2.6
TAN
ISO Code
