When using thick oils and you notice a knocking sound that sounds like its deep in the engine, what exactly is that noise? It sounds like the knock you get when you spin a bearing or something. It only lasts a few seconds and only when its cold. Just curious, my friend at work has a old 350 with over 200k miles on it and he uses 15w40 in it most of the time. He said it usually has a low knocking sound upon initial start up. Well he was out of town and his wife had the oil changed when she was out with 5w30 and now there is no more lower knock upon startup.
