Oil filter for Kohler Courage SV470-620
NJ
This engine clls for 12 050 01-S. The fram is PH8172 I believe. Is the number for NAPA Gold 1056??
Funny you should ask. Just changed my oil today, but decided to re-use the Kohler filter this time. But, I was looking for a cross reference for the Kohler filter. Here's what I came up with. Wix 51056, Fram PH8172 and in Purolator the L35310.
It does seem the Napa Gold number is the FL1056, the specs look right.
The Napa filter I have is 1056 not fl1056 are they the same?
Looking closer the online cat. # says FIL 1056, but yeah, it's the same filter.
Here guys
I personally run Motorcraft FL400s or Purolator Pureone equilvalent but on some Kohlers their isn't enough clearence
"Briggs/Kohler type" 3/4" X 16 threads 8-11 PSI Bypass Gasket 2.734"OD X2 .430"ID 0.226" thick
Length" Wix Purolator Hastings Kohler B&S Baldwin MotorCraft AC Walmart JD
2.3" 57035 NA LF503 2805001 492932 B7165 NA NA? NA ?
2.7" 51056 L35310 LF302 1205001 492056 B1410 NA PF2210 NA AM125424
3.4" 51348 L10241 LF157 5205002 491056 BT223 FL793 PF53 ST3614 AM101207
4.8" 51516 L20195 LF134 NA NA B243 FL400A PFL400A ST3600 ? 
Yeah, the OP's single cyl Courage has the filter oriented in such a way, you're limited on size choices. On the Courage V-twins like mine, the sky is the limit with space. I run FL400's. The blocks are pretty much identical to a Command block.
Joel
sayjac, Thanks!!!!and I guess the eyes are starting to go :)
