Originally Posted By: bustednutz
I have a 99 Chev Tracker 4 door hardtop with a 5 speed manual. Veehicle has 140K miles on it and I want to dump the manual gear oil from the transmission and replace it.
Does anyone know the proper weight to use? What kind should I use and how much does it take?
Thanks
Tell us which tranny! (Is it 4WD?)
Manual Transmission,4WD......GLS [2]
Synthetic Synchromesh Transmission Fluid (5W-30) (MTFQT)
Manual Transmission,4WD......GLS [3]
Synthetic Manual Transmission and Transaxle Gear Lube (75W-90) API GL-4 (MTGQT)
Manual Transmission,2WD......GLS [3]
Manual Transmission,NV3500......GLS [3]
Manual Transmission,......GLS [3]
[2] GM part no. 12345349 or equivalent.
[3] Synthetic gear oil, GM part no. 12346190 or equivalent
1999-2000 Tracker, if a determination has been made that
the 5-speed M59 transmission synchronizers have been
replaced, use synchromesh transmission fluid GM
